I am trying to model a handle. I used sweep 2 rails, using 3 profile curves to drive the cross-section of the handle. The resulting geometry was incorrect. What would be the best way to model this handle? I attached the .3dm file.
Thank You
HI Mason Your model has 2 problems. 1: The curves overlap, which can be viewed with the “_ShowEnds” command.
2: You also need to pay attention to the starting point of the curve
3:Height needs to be maintained. Handle.3dm (949.8 KB)
That worked perfectly. Thank You!
