What are the settings for an OBJ export from rhino V 6.0? my v5 is easy to export OBJ , no big deal& no touching the settings.
Hello - the settings are there to accommodate different target applications. Unless you can describe what is not working when you export from V6 and the settings that you are using, it is not really possible to advise you on what settings might work better.
hi I will try to take notes from it. v6.0 rh to obj, then in zbrush.
I use rhino 5 .0 also and have no issues exporting an obj file then importing it into z brush.\ thanks
thomas kurilla
i actually tried to copy the settings from v. 5.0 for the 6.0 no luck yet
Hello - So, the symptom is, you export obj from Rhino and import to ZBrush and some polygons are missing or incorrect, right? Now, can we see exactly what obj settings you are using? Can you make a screen grab of the Formatting and Mesh pages?
Sure thanks a lot!!! Later today
