In the attached file:
Problem Sweep 2.zip (271.2 KB)
I have this:
If I do Sweep1 using the open curve as the rail and the circles as the cross sections I get this:
It does not matter if I select the cross sections individually or together.
I have this:
Seems to work fine for me in Rhino 6!
Make sure that you click on the rail, when selecting it at the beginning of the command, where - at its beginning or end - you also start selecting the first cross section curves, and obviously highlight those in order along the rail curve.
Hi -
That doesn’t look right to me. It only works as expected when selecting from the top in Rhino 6.
I put it on the list as RH-62112.
