can somebody take a look of this? I am trying to do simple sweep, but it wont let me choose simple sweep.
Thanks!~
sweep 2( simple sweep).3dm (3.6 MB)
Thanks!~
Thanks for the quick help, Jeff~
So I made sure the endpoints contacted, and choose the rebuild,
unfortunately, it still doesnt work~
I wonder what else I have done wrong?
thanks again!
sweep 2( simple sweep).3dm (2.8 MB)
Hello - for a simple sweep, the conditions need to be pretty much perfect…
The rails have to match in structure - yours have different numbers of control points and are non-uniform.
The cross section curves must be placed on matching pairs of rail edit points. Yours is OK with the section curves at one end.
To make this work, use the -Rebuild command (dash in front). Select the upper rail as the curve to rebuild, and use the ‘SelectMasterCurve’ option - pick the lower rail (more complex by one point) as the curve to match. DeleteInput=Yes.
Now Sweep2 should allow a simple sweep but in this case, with the points arranged as they are, it is not a very nice surface.
I do not have access to a mac at the moment but I believe the above will work…
how many commands have that “dash in front” hide option? I saw a few examples like -viewcapturetofile which allows the user to set more options than the simple command, is there a list of them or something like that?
that -Rebuild with that “SelectMasterCurve” is awesome!
Hi Diego - in V6, both of these commands have the goodies ‘up front’ and do not need the dash…
Thanks Pascal~ It works!
