I’m trying to export some images from Rhino and I have noticed a weird thing happening…
In Display Settings I unticked Surface Edges but they still show in the Perspective view. (I checked for Top, Right, Front view… and they don’t show there)
I noticed they only disappear when I remove the Ground Plane…
Does anyone know why this is happening and/or how I can make the Edges go away and keep the ground plane?
Thanks folks!
Greetings from the Isolation in Vienna day 21937
here are some Images…(please ignore the colours, they made me do it…)
Yep, OK - sorry, I misconstrued what I was looking at - can you please run SystemInfo in Rhino and post the results, and can you send this file to tech@mcneel.com,. with a link back to this topic? I’ll take a look.
Hi Miruna - thanks - I did not realize we are talking about the Rhino WIP. Here, in V6 and the V7 WIP, your ini file imports with surface edges ticked:
Hi Miruna - I see the Zoom thing here as well, thanks for pointing it out . I’ll put that on the list - I don’t know if there is a useful workaround but if I find one I will let you know.
@miruna.vecerdi - So far it seems to be linked to the setting under Objects>Surfaces for ‘Naked edge usage’ If I change that to ‘Use surface edge setting’ it incorrectly toggles on surface edges, but here at least, if I then turn those off, the zoom level no longer affects the edges - I am still testing…
That was it i think!
I changed it to ‘Use surface edge setting’ exported and re-imported and now regardless of how much i zoom in or out or how rotate the edges are gone.
