Weird result from "Map to Surface"
I want to map the plane curve in the plane to a surface, but the result is wrong, any solution?
JSNIY~C_N6A%LJIRKK8HF
GH is attached: map to surface.gh (52.5 KB)
UV space has to be identical, otherwise you get a mess like above.
If you don’t understand, experiment with mapping between untrimmed surfaces.
I unrolled your curved surface again and used the boundary to create a new flat surface and then shrunk both surfaces (ShrinkTrimmedSrf)
map to surface.gh (25.4 KB)
You should try making the target surface an untrimmed surface (use edge curves to generate a new surface).
I recreated your surface to have an untrimmed one and then used the remap:
map to surface.gh (57.8 KB)
The problem was that the target surface (when untrimmed) is quite different when compared to the surface you want to remap to:
