I seem to have a problem with mapping some curves to a curved surface. As you can see, the mapped curves aren’t exactly on the surface but a bit above it.
I’ve grouped the components in the problem for ease.
I’ve tried all the quality settings but unfortunately the mapped curves are still not on the surface. I also don’t think it’s a quality problem as it’s become a problem down the line, where I want to extract the intersection lines between the brep I made and some intersection planes but the lines aren’t continuous because the mapped curves are floating.
thank you, that helped! Though it warped the patterns a bit (I’m working on another file with another pattern that I can’t share here because of confidentiality but the logic behind them are the same). Is there perhaps another way so that the projected curves are exactly like the original?
Try rebuilding your curve with more control points. For this sort of mapping, more control points make the curve more “flexible” so that it can conform to the target surface.
