Map surface to surface
Hello everyone,
Could someone please show me how to map a flat surface onto a complex surface?!
You can understand my problem in the GH file below. What I want to do is to map the curve onto the entire surface, not individual ones. I tried to reuinion either curves or surfaces, but it did not work. Please help me out!
Thank you very much in advance!
Best regards,
Anthony
Asking - Mapping Curve or surface to surface.gh (21.6 KB)
Like this?
Asking - Mapping Curve or surface to surface_re.gh (27.7 KB)
Hello MS_Kim,
This is exactly what I am looking for. Thank you very much! I really appreciate your help!
Best regards,
Anthony
Hello HS_Kim,
I would like to ask you for another favour. Could you please show me how to make a surface from the curves which are the result of Pull-curve?!
Warm regards,
Anthony
Is this what you want?
Asking - Mapping Curve or surface to surface_reV2.gh (32.1 KB)
Hello HS_Kim,
This is absolutely what I want. I don’t know how to thank you for your kindness, but I really appreciate it!
Thanks a lot, HS_Kim!
Warm regards,
Anthony
Hello HS_Kim,
To be honest, I do not want to bother you this much. I have tried many ways to figure out the solution I wanted but I did not make it. That is why I am ambrashedly asking for your favour again and again. I hope this is my last question for this problem.
Please show me how to get rid of the redundant "Trimmed surface"s from 6 to 11 in the Panel. Those surfaces might cause me problem when using BrepIBrep to trim the louvers with the surface (from Cull-pattern). Or maybe there are something else causing the problem.
Best regards,
Anthony
Asking - 29-8-2018 -Mapping Curve or surface to surface - Trimming.gh (313.1 KB)
I dont think you want to get rid of those “redundant” surfaces since they represent the leg of the cheetah? If you ‘graft’ the surfaces from Cull-Pattern you get the desired result (i believe).
To graft -> Rightclick on the Surface Component -> Graft
As Nils said…
Asking - 29-8-2018 -Mapping Curve or surface to surface - Trimming_re.gh (311.0 KB)
Hi Nils,
It works perfectly. Thank you very much! I really appreciate your help!
Best regards,
Anthony
Hi HS_Kim,
Sorry for the misunderstanding the surfaces! Everything is perfect now! Thank you very much!
Thanks a lot!!!
Best regards,
Anthony
Hi Kim i was having a look at this definition and it shows that there were unrecognized objects named Relay, i tried to look at the screenshot of the definition but the missing parts were not labelled nor were there any symbols for reference ?
I am currently using Rhino 5, could this be because we are using different versions ?
could you please enlighten me as to what they are ?
images below to show you what i mean
Thanks
Relay is a Gh1+R6 component. It doesn’t do anything besides pass data in a way that makes the wires look cleaner.
Noted with thanks
