Hi!
Can someone maybe help me with this issue? i am trying to join all these curves to one closed curve. But everytime i join a few or all together i get weird lines as output. is there a solution for this? Thankyou for your help!
Hi!
The only way to be able to figure out what is going on is for you to upload the file so someone can look…
That being said, those dim horizontal/vertical lines I see - are they the Grid? If so it is likely your curve is extremely tiny relative to the file units and tolerance which will always cause problems. But it’s impossible to know without seeing the file.
Thankyou for your reply! so stupid i did not notice my data imported so small, i’m working with a lot of data layers so i got confused. maybe that is the reason, i will try it on a different file and let you know if it worked! otherwise i can update the file.
Thanks again!
