I’ve learned that Weaverbird no longer works in Rhino 6 without the use of Grashopper. I’ve never used Grasshopper before, so I am pretty clueless as to how I’m supposed to apply for example a Catmull-Clark subdivision to a 3D model I own?
Edit: I’ve installed the plugin already and I can see I have the commands in Grasshopper, I just don’t know what to do with the typical Grasshopper block. I have no clue how this works and don’t really have the time to get fully immersed into it…
Hello
I am not on my pc but as there is now catmull & Clark subdivision in rhinocommon it must be possible to implement a command in Rhino. @piac can you help?
If you have Rhino 6, just install the Rhino 7 WIP: you can use the new Subdivide command there to apply Catmull-Clark. In addition, Subdivide has more advanced texture support compared to the old Weaverbird command.
For what I know i used the c# version in rhino 6 for more than one year, it was visible then not visible through autocompletion … Now it appears in the rhinocommon wip documentation
