Most of the time I use C# components of my own, but I want now to insert lot of function inside a single C# instead of copying the codes each time I want to make a DLL that will contains all my classes, static function … Does I have to use
.NetCore (1.0 1.1 2.0)
. NetStandard (which one 1.0 1.1 … 2.0)
I found and I used template for Rhino and Grasshopper. Is there an example for a DLL ?
I tried .NetStandard/.NetCore with no compilation error and I get an error message in Grasshopper. What I miss ?
An example I used (Thanks for the new function in RhinoCommon)
using Rhino.Geometry;
namespace TestClassLibrary1
public static class Class1
public static Mesh Catmull(Mesh mesh, int level, int creasedEdge)
Rhino.Geometry.MeshRefinements.RefinementSettings rr = new Rhino.Geometry.MeshRefinements.RefinementSettings();
rr.Level = level;
Rhino.PrivateMeshCommands.MeshTypes.CreaseEdges ce = Rhino.PrivateMeshCommands.MeshTypes.CreaseEdges.Auto;
switch (creasedEdge)
case 0:
ce = Rhino.PrivateMeshCommands.MeshTypes.CreaseEdges.NakedFixed; break;
case 1:
ce = Rhino.PrivateMeshCommands.MeshTypes.CreaseEdges.NakedSmooth; break;
case 2:
ce = Rhino.PrivateMeshCommands.MeshTypes.CreaseEdges.CornerFixedOtherCreased; break;
case 3:
ce = Rhino.PrivateMeshCommands.MeshTypes.CreaseEdges.Auto; break;
rr.NakedEdgeMode = ce;
return Mesh.CreateRefinedCatmullClarkMesh(mesh, rr);
