Hi, is there a way to measure/determine points on a rounded surface via the circumference? Kinda like taking a tape measure and wrapping it around an object? I see there is the CreateUVCurve command, it would be similar to that I guess, thx
Hello - you can Project
a line or curve onto a surface and use Length to get the length of the result - depending on the situation that might do it. You can also try InterpCrvOnSrf
and measure the result.
Also, to measure between two points on a single surface, ShortPath
and then Length
on the result.
Thx so much, I’ll give that a go.
