Beginner Here! How Do I Check Dimensions for an Object?
Hello! I’ve been playing around with the program for a bit and I must’ve forgotten how to check dimensions for curves, lines, etc. Is there a setting or a tool I can use to find the dimensions of them?
Thank you so much!
Probably a better command set but you can use “what” command or “length” command
There are also commands such as:
Length
Distance
Area
Volume
Radius
Diameter
Angle
