Wavy pattern in curve facade Grasshopper Pls Help
Hi everyone, I’m reaching out because I’m having trouble creating a vertical wavy pattern on the interior surface of my atrium façade. I’d like the inner surface to have the wavy pattern, while keeping the exterior curve unchanged so it can connect properly to the structural frame. The total thickness of the façade is intended to be around 70-100 mm.
I’ve tried using random curve mapping and the Anemone plug-in, but the results either don’t generate the pattern or distort the surface entirely. I’ve attached my working file below.
I am still new to grasshopper so if possible, could you kindly guide me on how to approach this? I would really appreciate any advice.
Thank you so much for your time.
interior.3dm (1.1 MB)
internal.gh (29.6 KB)
See if this can be helpful.
internal a.gh (23.3 KB)
yesss it doess. Thank you so much!!
