Wavey Unrolled Surface
Hi All,
I am trying to make a curved balustrade for a staircase although when I try to make it using unroll I get a wavey effect. The wave is on the unrolled surface but not on the 3d one. This wave is also transferring to anything I flow on the surface. I have attached some images below.
Thanks in advance.
Hello - please post a file with that surface - my guess of the moment is that tightening the file tolerance by 10X may clean up the unroll.
Hi Pascal,
Please use this link to download the file.
Thank you.
Hello - there are two problems - one is tolerance:
Please see https://wiki.mcneel.com/rhino/faqtolerances
Fixing that is a great idea but does not help with the unroll - cleaner more precise modeling will, however.
UnrollCleanly.3dm (110.6 KB)
I don’t see anything wrong with the current unit settings.
Could you resave the rhino file as version 6 please?
Hi -
You can find a conversion tool here:
