I am attempting to build this as a scale model. Cutting out of sheet material.
My first attempt is unrolling my sections separately from a split surface. They line up on the one half just fine but everything gets really wonky on the other side!?
I then did it with one surface and just took the curves with it. Which is giving me a slightly different shape altogether.
What is the proper way to do this to ensure everything will line up in my scale model?
Note: My tolerance works fine at .0001 with everything except the Jurassic text I need to change the tolerance to .01???
UnrollProblem.3dm (2.0 MB)
