Wallacei problem
hi
i have a problem when i run wallacei.
i have only 2 objectives but in wallacei setting there are a lot of fitness objectives called F01…FO3420 and it increased the run time of wallacei
i don’t know what should i do
thanks for your helps
Double check the number parameters that are holding the fitness objectives. Most likely they are holding more than one value. The best practice is to make sure each number parameter only holds one fitness value and to be flattened.
