Wallacei converges the building volumes
Hallo ,
I want to use Wallacei in a file optimization that worked fine with galapagos , and I have four volumes to be optimized according to solar irradiation on the facade in a building plot - the volumes should not be outiside the plot and closer than 8m distance. the genes are that each volume can move in the x, y, and rotate. and that height can alternate between them.
In wallacei the simulation finishes in seconds and all the volmues are converged .
it seams like t doesnt read the volumes correctly and the restructions.
hello, please upload your file for us to take a look at. It is impossible to help like this
Thank you very much. I think one mistake is the individual connection of the genes. Can you please confirm ?
Scenario A_FAR_4_.gh (206.7 KB)
Please simplify the problem using a minimal example file with as few extra plugins as possible, and then share the file
you are right . please see attached. thank you !
Check offset overlaping before optimization_TMP_02_DummyRadiation.gh (140.9 KB)
