Wall openings
Hello
I have found that in walls thicker than 40 centimetres, windows equal to or smaller than 100x100 cannot pierce the wall on both sides.Esterno Interno
Hi @caterinasalvatori , that’s strange. Doors and windows detect the host wall thickness and assign an automatic Cut Depth value that is higher enough to perform the whole cut across the wall. Is that wall created from a solid? In those cases the wall thickness is unknown and that would explain your situation.
In any case, you can edit manually the Cut Depth value of the window and ensure it generates the opening.
