Curtain wall / window
In new model, windows seams not to works in curtain wall. Curtain wall isn’t interupted…
I used to do it before, it worked fine
now:
Before:
Thank’s
Hi @guillaume.dupas please share a file we can test this issue and figure out what’s happening.
https://derbesse-my.sharepoint.com/:u:/g/personal/guillaume_dupas_ddd-architectes_com/EZNPFNYghdNGlnNoBCS8EDEBW-aSfm7OPxmk8aY_yqkudQ?e=R2qRhf
Thanks! I’ll forward it to developers and get back to you when find a solution.
Maybe there is a bug with window alignement parameter
Hi @guillaume.dupas, we have realized that the “cut depth” of that window is too small. If you change it to a higher value and relocate its position across the curtain wall, the opening will be generated properly.
test.3dm (3.2 MB)
Hello, I tried it but it doesn’t change.
Can you help me understand what is wrong? On this project, it is impossible to shift a window, it comes out of the wall every time… is it a problem adjusting the wall or the window?
Hi Guillaume,
This is what I see when I open your file in VisualARQ 2.13 on Rhino 7:
Apparently all windows perform the openings correctly on the walls.
What do you see in your case?
Yes, I can see that too, but when I move the windows slightly, they don’t fit back into the wall.
Try to place the window on the wall path:
wall window
Doesn’t work when I move window on the wall…
