why the line of the wall is too thick with a window? and how can i change that?
Thank you.
Hi Hugues, check out if the section attributes assigned to that wall are different than the wall projection attributes.
If you want to send the file to visualarq@asuni.com we will check it out too.
Ok yes perfect it was this!
Thank you
