Wall Family with non-planar surface from rhino
Hello, have multiple non-planar surfaces joined with fillets, modeled in rhino, on tjis surface I am trying to creat a wall in revit, similar with directly applying a wall on a mass surface directly in revit, but with grasshopper.
I can creat the wall objects in rhino as solids and importing them in revit as generic models, with direct shape, applying materials with custom parameters from grasshopper. I also tryed to add new parameters in the direct shape, but i failed.. :slight_smile:
I would need some help, if someone knows a way to creat this walls as a wall family not a generic model, also i would use it for facade panels that are all non-planar curved surfaces. an example in images attached bellow with the geometry and the code
Hi Filip,
For optimal control you may want to have each face as a Generic Model and then either manually add the wall by face or try the scripted component here.. Wall by Face from mass generated in Rhino
As much info as possible makes it easier for us help-us-help-you Thanks!
Hi Japhy! @Japhy
What if the add wall by face doesn’t work? I tried clicking the generic models, but it won’t let me at all, can you please help?
