Wall extension problems
Some of my walls disappear when I extend the tops to a poly surface and I don’t know why. I just installed the update 2.8.4 and it still happens. Does anyone know why this might be?
Hi @seflorance,
Can you send me a sample 3DM to visualarq@asuni.com so we can check what’s going on?
Thanks,
Enric
Hi Enric, I just sent the file, let me know if you need anything else
Hi @seflorance,
We’ve got your file. Try to change the Absolute tolerance to 0.001 feet. Then select all objects and run the vaUpdate command. Does that fix the problem?
In any case, we will try to fix this whithout the need to change the Absolute tolerance.
