Hi, I have met a problem when I use Wall Extend commond, it doesn’t work when the boundary objects are Polysurface, I want to know if any method I can extend the wall to this polysurface, I tried explode polysurface to single surface and extend one by one, but it can’t work when I execute the commond second time.
@11181 can you send the model to visualarq@asuni.com? We will check it out. I’ve tried a similar case and it worked!
Thanks, I have sent the model to you.
wall extend.3dm (264.9 KB)
@11181 thanks for the file. We will check the model and try to fix that error as soon as possible. I’ll keep you posted.
@11181 This bug has been fixed in VisualARQ 2.3, that is already available to download. VisualARQ 2 - Version 2.3 released
Thank you for the fix!
