It’ll work only as long as the block is open for editing, and the walls unextend as soon as the block is closed.
Please, add further details.
Attach a screenshot/video and/or a rhino file where to repeat the problem.
What is “Extend Walls”?
Is it a command from a plugin?
Ah.This belongs in the VisualArq forum. Sorry about that.
Hi @djhg I cannot reproduce this issue.
I extend a wall to a block. I double-click on the block to modify it. Exit the block edit. And the wall extension updates to the modified block.
Please share some example to test that is not working on your side.
Thanks Francesc. In this case both wall and roof are in the block.
Hi @djhg I see it now. Actually, when I try to edit the block, the wall disappears in my case. This is a known issue that we are waiting to fix. I’ll keep you posted!
By the way, it appears not to be a problem if the block is external.
Hi @djhg @maje90 I’m glad to inform you this error has been fixed in VisualARQ 3.1, which is already available to download: Update - VisualARQ
