Hi all!
I am having a few issues with a waffle script.
- How do I loft the contours in grasshopper so that they trim to match the shape of the surface? They are currently just curves and i would like to give them a thickness. I have tried to extrude the curves manually in Rhino and they hang out of the surface as each curved contour is matched to a specific part of the surface.
- The intersection cutting points for laser cutting don’t seem to match up with the contour curves in some areas. They are in fact sitting above the surface. See the image below for reference.
I do apologise if i’m not 100% clear. Do not hesitate to ask for further explanation should it not make sense. GH script and Rhino file are attached at the bottom.
Thank you in advance.
Phillipe
test.3dm (145.9 KB)
2012_01_02_contour.ghx (363.6 KB)
