VSCode Rhinocode Extension
@eirannejad I found RhinoCode - Visual Studio Marketplace but do not get it to work. Is it actually functional? What are the steps to run code remotely in Rhino? Thanks for your help.
It is work in progress. Currently the extension adds a command to vscode named “Run in Rhino” that can run the script you have open in vscode, inside a running instance of Rhino on your machine. It needs a little config to know where your Rhino is installed
Does it support debugging?
