VScode to Rhino8 bug
Hi there,
I love the new feature to be able to run VScode and visualise on Rhino8 through Rhinocode. The feature works well for me, however sometimes on running the VScode file, I get the error ““There are no instance of Rhino WIP running””. I am having to restart to make it work, not sure why I get this error. My settings in rhinocode are configured to my python path.
I have Rhino 8.6
Windows PC
any suggestions would help greatly!
thanks!
@keerthana Are you working on Rhino for Windows?
Hi @eirannejad thank you for your response, yes i am using a windows pc
Okay when you see this problem happen, open a terminal (powershell) and:
# go to rhino installed directory
cd "C:\Program Files\Rhino 8\System"
# run rhinocode command to list instances of Rhino
./rhinocode list
it should print a report like this listing one rhino instance:
       PID ID                             DOC                  PATH
     42788 rhinocode_remotepipe_42788
If it does not list anything, vscode is not gonna find rhino.
Then in Rhino run RhinoCodeLogs and DM me the contents to see if anything is broken
Thanks :smiley:
Hi @eirannejad
thank you for your response!
This error doesn’t show up for me anymore but it was a lot of restarting and refreshing.
I need your feature for a workshop and some of the participants encountered this issue. It would be great to know if there is a fix in the next two days (since i have a workshop)
I’m pasting the output one of the participants below:
Thanks in advance
Is there any way you could upgrade to Rhino 8.8 and test that one?
Hi @eirannejad thanks for your response,
yes updating to 8.8 does seem to solve it, alternatively opening script editor in rhino and closing it helps (oddly). I noticed that Rhinocode is not in the VScode market place anymore?
thanks
Keerthana
It is still there. Does this link not work for you? RhinoCode - Visual Studio Marketplace
