I’m going to buy a new PC for working with Rhino and Vray, and some Photoshop. And I have runned into a dilemma, CPU or GPU?
Now I’ve tried to mess around with it a bit, and look up all the information and I still cant figure it out. From what I’ve read, it seems like GPU rendering is the long term solution. But I simply cant figure out how to get Vray to render with my current GPU.
No-matter the settings (GPU acceleration or not) the computer still max out the CPU usage and barely uses the GPU?
I would really like if I could force Vray to only render with the GPU, so my computer was’nt useless while it renders.
Yes, you’re right, V-Ray settings set to Progressive/GPU Acceleration, I’ve got a small peak of 20% on the GPU while the CPUs were between 90 and 97%. 1m45.4s for my test scene.
Settings set to Progressive/CPU and about the same GPU/CPU usage. 1m43.8s for my test scene.
It’s only when the “Interactive” switch is turned on that the GPU gets a workout…
