Vray mat mapping
Hi everybody,
I’m trying to render a VA model, after assigning the material from the wall style, but the map size doesn’t change when I modify the box mapping…
Any suggestion?
Thanks
Hi @arkfavero,
The display of texture mappings on VisualARQ objects doesn’t work well due to a Rhino issue related to texture mappings applied to blocks (and VisualARQ objects are actually blocks). However, if you shot a render, the result should look fine. We have already reported this issue to McNeel development team.
Best regards,
I found a way to partially solve the probem.
Simply change the u and v repeat number to adapt the size of the texture from V-Ray texture editor.
Obviously for all the textures of each material.
@arkfavero this issue has been fixed in VisualARQ 2. The materials on VisualARQ objects need to be assigned by style, to make the Rendered display work properly.
