Mapping blocks Visual Arq - Vray
i Hello everybody,
I have a problem rendering visual arq blocks (walls). I can not change the mapping of the textures (rotate, etc.)
that’s a bug in Visual Arq or VRay
Thanks and regards
Eike
Hi @ERahjes!
If you want to use texture mapping the material should be applied to the hole style, not to its subcomponents. Once the material is applied to the style you will be able to see it (with the Realistic or Rendered display modes) and you can start to set your desired texture mapping.
Currently the only drawback is that you will need to select the object that you are working with and run _vaUpdate after every change.
WallTextureMapping
