Vray 7 does not load on rhino 8
I just installed vray 7 and I get an error message when I load rhino 8.
(in rhino 7 it works fine)
Try to load the plugin manually
it’s not working
It is obviously a compatibility issue.
What version of Rhino 8 you have ? V-Ray requires Rhino 8 SP4 as minimum. Also make sure you install the .rhp file in the V8 folder on Rhino 8 and in V7 on Rhino 7
this is my rhino
‫בתאריך יום ד׳, 25 בדצמ׳ 2024 ב-16:17 מאת ‪Nikolay Bakalov via McNeel Forum‬‏ <‪notifications@mcneel.discoursemail.com‬‏>:‬
do you have a solution for this problem?
I don’t since I can’t reproduce it locally. There isn’t an universal pill to fix the problem, since it only happens on that particular machine of yours. You’d better reach out to Chaos support to arrange a remote session.
