Voronoi and then offset error
Hi I have used offset to make each voronoi cell have a smaller offset, and I assume the error is maybe the order of the points in the original voronoi, but what would be a good way to fix it? should I just reset the points themselves?
https://discourse.mcneel.com/t/welcome-to-mcneel-forums/483/2
not sure why you linked me to that page, but it doesn’t really help much
Generally, it’s very hard for people to help you when you only attach a picture. Please attach the gh definition with any Rhino geometry internalized.
Perhaps it was this page that Tim had in mind:
Hello there, I have the similar problem with offset. Some polylines generate no ofset curve at all or a really broken curve, usually very small. This has to be caused by some small segments in the original polyline, but When I use offset command in Rhino, it usually works fine. What is the difference between the Rhino command and Grasshopper command offset?
