VisualARQ section view projection
I’m really pleased that there is an option to turn off the projections for section views, but there seems to be an issue with this.
If I turn off the section projection toggle, what’s left are the curves of the cutting plane AND the plane where the projection is supposed to end. I don’t think this is the way it was intended to work or am I wrong?
Hello @brglez.primoz,
I couldn’t reproduce it. Which Rhino and VisualARQ versions are you using? Could you send me the file to visualarq@asuni.com?
Rhino Version 7 SR8
(7.8.21196.5001, 2021-07-15)
VisualARQ Version 2.11.0.15006 - (2021/06/14)
Thank you for your file. I am adding this issue to our list for the next release. For now, as you only need the section lines, a possible workaround is moving the Section length control points until they are not cutting the object.
VA_Section_Projection.3dm (17.1 MB)
Hi @brglez.primoz , we have just released a new version of VisualARQ (2.12) which fixes this issue.
You can check here the news of the new version: VisualARQ 2 - Version 2.12 released
Enjoy!
