2D views not show correctly
The latest VisualARQ 2.11 has the option to show plan and section views with no projection, but I found when the objects are not solid(such as surface) when I choose no projection, there is nothing to show. Is there a way to solve this problem?
Hi @11181,
I’ve tested now, and in a section view, the intersection curve between an open surface and the section plane is shown when the “Show projection” option is disabled.
Can you send us a sample model so we can take a look?
Thanks,
Enric
Yes,in section view there is no problem, but in the plan views, the intersection curve has this issue.
Hi, I test some other files, but the plan view always shows nothing if it is not solid, hope to fix this soon, thanks!
I’m looking at this issue right now. My plan is to fix it for VisualARQ 2.11.1.
Enric
@enric
Do resales this version now?{VisualARQ 2.11.1}
Thanks!
Hi @11181
This bug is fixed in VisualARQ 2.11.1. We will publish it early next week.
Thanks,
Enric
Hi @11181, we have officially released VisualARQ 2.11.1, which fixes the error you reported here. VisualARQ 2 - Version 2.11.1 released
