How do I export plans and sections from Visualarq to Illustrator to adjust line weights?
@_MIGUELunderscore you can create 2D plans and Section views with the vaPlanView and the vaSectionView commands respectively. Then you can export these curves for post-production in Illustrator.
But take into account that with the VisualARQ section attributes that can be assigned either to VisualARQ objects (by style) as to Rhino geometry (by object), you can already assign section hatch patterns and line-weights for printing purposes.
Take a look at this couple of videos that show how to assign the section attributes and create plan and section views (https://youtu.be/JHk1vJ1r0wo) , and printing a project to vector output (https://youtu.be/1qdNB5v_fwE).
Thanks for the help.
