VisualArq objects within rhino blocks, 'breaks' the va blocks
I found out the following is only with the BlockEditNew plugin (which is extremely useful)
When I block together several VA objects (wall and doors into an ‘apartment block’, to copy multiple times into a building) - it ‘breaks’ the va objects into rhinoblocks with a name like "*Wall{e198… etc.. If I explode the parent block (the apartment), all the VA objects are still ‘dumb’ rhino blocks..
Any clue whether this compatibility could be resolved? Thank you!
@florisd
If you put VisualARQ objects inside a block, you cannot create a unique copy of that block with Rhino commands. Because VisualARQ objects are in essence blocks, Rhino copies them “dumb” without the intelligence.
Workaround is to open a new Rhino instance, copy/paste the block there, change the name, and copy/paste it back.
Thanks that’s a useful workaround for the CreateUniqueBlock incompatibility.
@fsalla @enric It would be great if the development of VA could reach out to the developer of BlockEditNew for compatibility : wucl12@foxmail.com
Thank you!
they seem to be in contact, hopefully they can fix this soon
@Sebastian_Wimmer We are still pending to help the BlockEdit developer to make it work properly with VisualARQ objects. There has been no progress so far in this interoperability.
@Sebastian_Wimmer I confirm we have been able to fix the compatibility issues between VisualARQ and the BlockEditNew plug-in and they will work fine in the upcoming VisualARQ 3.10 update. We will publish a Release Candidate version of it next Wednesday in the Forum.
that is amazing, thank you for the very fast fix!
wow - looking forward to using this - I applaude you! thanks for looking into it
if mcneel implements groups into blocks then the world will be a better place
@florisd @Sebastian_Wimmer I let you know that in VisualARQ 3.10 RC1 we fixed the issues between VisualARQ and the BlockEditNew plugin. Today we have published another 3.10 (RC2): VisualARQ 3 - Version 3.10 RC2 released
Let me know if you find further issues.
thank you - until now, everything seemed to work, I once managed to crash it, and then some elements got converted to blocks - but was not able to reproduce that. I will update, if I encounter some issues again.
Hi @fsalla I found a bug and would want to know if you have the same issue. If I place visualarq elements into a block, for example beams, and then klicke the “unique” button in the blockedit_new interface - the behaviour is the same as it was before you made blockedit_new work with visualarq elements. this means the visualarq element travels in space to a different location and loses its visualarq state and becomes a mere block.
best regards,
sebowim
Hi @Sebastian_Wimmer yes, I could reproduce this error. I’m not sure if this is something we can fix from our side, or from the BlockEditNew developers. Perhaps @ChenglinWu can take a look too.
