Visualarq model export IFC from rhino 7
I’m experiencing an issue when trying to export a VisualARQ model to IFC. Some native VisualARQ elements are disappearing randomly. For example, one window doesn’t appear in the IFC model, while all the other windows of the same style do.
Where could the problem be coming from?
Hi @tikito can you share that model. That way we can try to reproduce this error and figure out what’s happening. Thanks!
Hello Fransec,
The model is too heavy too share here, there is an other way to sent it to you ?
You can use https://wetransfer.com/ you can post it here or send it to visualarq@asuni.com
@tikito Got your file, thanks!
What program do you use to open the IFC file? Have you tried others? I’ve tried to open your file exported to IFC with BIMCollab, and all windows seem to be there…
Can you share the IFC you generated as well?
When i open the ifc model in rhino, the windows appears but in autodesk viewer for example, it does’nt…
In this case, it might be a problem from the Autodesk Viewer side, which we can’t help, unfortunately.
