IFC command don’t work and i can’t save in ifc format
Hi @Henry_Boutet_de_Monv first of all make sure that VisualARQ is loaded in that Rhino session (just run any command, like “vaWall”). If you still can’t export to IFC, go to Rhino Options, plugins, (plugins that do not ship with Rhino), do right click on the IFC Export plug-in, and enable it.
Then try to export your model to IFC. Let me know if any of these options solves the problem.
Hi @Henry_Boutet_de_Monv try to uninstall and install VisualARQ again.
When you open this file again, make sure VisualARQ loads (run any command), and then save the model as IFC to export it.
Let me know if that solves the problem.
Hi @fsalla, its works but i can only export in IFC 2x3. Is there a way to export in IFC 4 ?
Hi @Henry_Boutet_de_Monv not yet. We are working on that and we expect to provide the IFC 4 export in the upcoming updates. The Import of IFC 4 and IFC 4.3 is already available.
