VisualARQ Levels display bug
Hi @fsalla
there seems to be a bug in the display of curve objects through shutting down Levels.
Rh8 SR12 // VARQ 3.0.8
Hi @Toni_Osterlund I see. It looks like the guides are not properly hidden when hiding levels. Or do you mean any error in the other curves?
Have you activated the option to display the guides “on every level’s elevation” intentionally? you know that you can change that in the guide styles dialog:
@fsalla
The quides are not VARQ guide objects, but curves.
I started this project with Rh7/VARQ2, but had to move this particular drawing set to Rh8/VARQ3 due to printing issues.
How is the “clippable” setting of these curves?
If it is enabled, the curves should not be visible.
@fsalla
The problem was resolved with the latest update.
