Hello
I am unsure how to use the sizes parameter on VisualARQ (which appears in a couple of components), since both ‘sizes’ and ‘profile’ expect a profile object.
Thank you in advance
Luiza
Hi @Luiza_Longo,
In your definition, you are creating some beam objects and also a beam style.
The “Profile” input of the beam style component is used to define which is the profile of the beam style.
The “Sizes” input of the of the beam style component is used to define a list of sizes for the beam style. These are the “predefined” sizes that you can also create in the beam styles dialog:
The “Profile” input of the Beam Options component, is used to set some dimensions to the beam objects, regardless of those predefined sizes of the beam style. The profile shape must be the same as the one of the style though.
Find attached an example on how to generate a new beam style with a list of predefined sizes. Let me know if you have any questions:
Beam Style with Sizes.gh (12.8 KB)
Hello!
Thank you for your answer.
Still, I have one remaining question. How do I choose from the list of sizes that was created directly in grasshopper? I have found the new beam style on the Rhino dialog.
Best
Luiza
Custom Profil.gh (16.3 KB)
I would like to do the same thing, but with a custom profile: a metal sheet profile.
Once the beam has been created, I would like to have the option to choose between a detailed version using the actual profile, or a simplified version using a bounding box rectangle of the profile.
Is this possible?
Thank you!
Hi @Romain4, VisualARQ beams created from custom profiles can only have 1 size for that profile (which is automatically calculated from the boundary XY dimensions of that profile).
If you want to have a beam style with different custom profiles, you can do it with a Grasshopper Style.
Then, the custom profiles can be managed by a list of internalized curves in a Data component, and then use a Value list parameter to chose one or another. Or just use a couple of curves for defining a different level of detail of that profile.
Once the new beam style is created, you can reference it in Grasshopper using the Beam Style component, and then figure out the name of the parameter you have used to chose one curve or another of the beam profile (you can use the Property Names component for that), and change the value with the Set Property component.
