Probably a quick solution but I haven’t yet found a solution on this after searching and seen through tutorials and videos online.
I want to have the opportunity to select the pre-defined profiles from beams and columns the same way as Beam Styles are selected. Alternatively as a text string. Hope this is a quick fix and just something I’ve missed. Se also attached picture.
Hi Alfonso, Thank you very much!
So it’s “Sizes” defining which profile. Then I get it. Would be easier with a right-click option there though. Have to figure out an easy way to make this a simple value list for the end user.
But again - thank you very much for quick reply!
Best regards Nikolaj
Thank you so much for these ideas! I think the first one about the right-click could be feasible. I’ll think about it just in case something similar could be added to our wishlist with your vote.
