VisualARQ - How to access "Description" parameter inside Gh-style?
how can I access the object Description parameter from inside a Gh-style?
I tried to use %<element.description>% in a string component, but it does not work. All I see are hastags.
I know I could create another string input field and use that, but as I already have the Desciption by default, I would like to utilise it.
Gh-style_description.gh (17.1 KB)
Hi @Toni_Osterlund,
You can use the “Get Property Value” for that:
Description.gh (3.4 KB)
Hi @alfmelbev
that would work with the final object.
But I’m defining here a gh-style script. I do not have an object to query, because it does not exist yet at this point.
@fsalla
Any wisdom on this issue?
Hi @Toni_Osterlund,
We have been making some tests and it is possible to use string properties values as input for Grasshopper Styles, but there is a problem when retrieving the description value. We are working to solve this problem and I will let you know when it is solved. For now, you can retrieve the name property instead as a workaround; this is the workflow you need to follow:
Annotation
This is what you need to use as a name of the Text param: %<this.name>%
Annotation.3dm (2.7 MB)
annotation.gh (3.3 KB)
