VisualArq GH Slab from Curve Outline
@enric @alfmelbev
I am trying to make a Grasshopper based slab style that uses the curve/surface from the “FromCurves” or “FromSurfaces” option of the _vaSlab command.
The example on your website shows only parameter inputs: Slabs roofs - VisualARQ
I know I could make a curve input and assign a curve after creating the slab. I would like to avoid this, because it is very confusing behavior and users of the style need to read through extra documentation to understand how it is done.
Thanks
Just found: Grasshopper styles input for slab - #2 by fsalla
Is this still the case?
Hi Silvan,
You found the right post. We need to add as input geometry a boundary curve (or surface) for slabs created from GH styles. That’s planned for VisualARQ 3.
Hi @silvano in VisualARQ 3 you can define a boundary curve for slabs and roofs created as Grasshopper styles. You can see an example in this video: https://youtu.be/789JeSaVKeY?si=DLApLR5vcWEZqdjk
