Slab, wall and rails grasshopper style
Hello there,
I would like to know the best practices to make slabs, walls and rails.
Is just start with a line from 0,0,0 and go X axis all the way? Or is like doors that you start at the 0,0,0 but it goes X and -X in X axis?
Also, in walls I would like to know if the wall hosts an openess such as doors or windows, if there is a way to generate a wall frame? Since it happens in some systems such as drywall and steel frame.
Hi @Leo13
Each object type requires a different input geometry as generator: a path curve for walls, a flat surface or closed boundary for slabs, an insert point for doors and windows (aligned with the coordinates origin)… There are different tutorials and examples to create Grasshopper Styles for each object type on the web: Grasshopper styles - VisualARQ
Furthermore, you can find useful information at the VisualARQ Help for creating Grasshopper Styles: Grasshopper Styles | VisualARQ help
Unfortunately it is not currently possible to include in the Grasshopper definition that generates a wall style the information of the future objects that will be hosted there (doors/windows), in order to make the wall adapt to it. That’s something we plan to improve in future versions.
How does close boundaries for slab work? didn’t find in the documentation. I could define the boundary or it has a comand for the user to define a boundary and then I explode the boundary to use a guid line in X axis?
Hi Leo,
Find attached an example of a Grasshopper script used to create a Slab Style (the one published here: Slab with Hatch | Food4Rhino
Tiles Floor with Hatch.gh (13.3 KB)
In this case, a surface is used as input geometry. The process of using a closed curve instead would be the same. The advantage of using a surface is that the resulting slab will be sensitive to the vaSlabAdd and vaSlabSubtract commands.
You can see a video of the process: https://youtu.be/aboyncNczOc?si=GSFVJvbUjhYLGC4G
