Hatch pattern in plan section view not visible in Layouts tab
in the first image, it shows the working image showing the hatched pattern for VA walls plan cut but
in the second image, the hatch is not shown and the layout loads and moves slow, it did load correctly in the first time but eventually when the file size increases this error happened , is it possible to correct this
i move to older version and disabled hatch scaling that did the trick
i have the solution affirmative
Hi, if this issue has to do with the hatch scaling, there’s no reason to move to an old version of VisualARQ. The behavior of the hatch scaling will be the same.
