Hi everyone,
I’m having a persistent viewport rendering bug on Rhino 8 (Windows) when switching from a multi-monitor setup to laptop-only use.
The Issue:
When connected to my secondary monitor, Rhino 8 displays and functions normally.
As soon as I disconnect the external screen and run Rhino on my laptop display alone, each of the four viewports locks up—rendering model geometry only within a small quarter-quadrant of its respective viewport area (leaving the rest of the canvas unresponsive or misaligned).
Maximizing a single viewport only maximizes that quarter-box state rather than filling the screen.
What I’ve Tried So Far (Unsuccessfully):
Standard UI resets (
4View,Reset, restoring viewport layouts). -
Deleting
%APPDATA%\McNeel\Rhinoceros\8.0\settingsandUIlayout/window position XML files. -
Performing a full factory reset via the
Resetcommand. -
Overriding High DPI scaling settings in Windows compatibility options (hopefully I did not mess up too much there as there was a lot of back and forth)
Updating to the latest Rhino 8 release.
Key Observation:
- Running Rhino in Safe Mode resolves the viewport split completely, which suggests a display pipeline, GPU frame-buffer, or scaling handoff issue when switching monitors.
Here is a screenshot of the viewport glitch along with my systeminfo. This is an AI summary of everything I’ve been through, so feel free to be critique about the steps explored.
Thank you,
Romain
Rhino 8 SR36 2026-10-20 (Rhino 8, 8.36.26293.11001, Git hash:master @ 824eaa40694d0076394d36eac84fb3109a9f5f62)
License type: Commercial, build 2026-10-20
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 63GB)
.NET 10.0.2
Primary display and OpenGL: AMD Radeon™ 610M (AMD) Memory: 1GB, Driver date: 8-20-2026 (M-D-Y). OpenGL Ver: (null)
Integrated accelerated graphics device with 5 adapter port(s)
Secondary graphics devices.
NVIDIA GeForce RTX 5070 Ti Laptop GPU (NVidia) Memory: 12GB, Driver date: 4-8-2026 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
- This device is not being used
OpenGL Settings
Safe mode: On
GPU Tessellation is: On (but disabled due to other settings)
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 8-20-2026
Driver Version: 32.0.21036.11002
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 256 x 16843008
Total Video Memory: 512 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.36.26293.11001
