When I first opened it, it didn’t have any issues. But in another file (included below), I copied the screw, and pasted it into a new file, and then I immediately got white in one of the viewports. When I switched back to tryThisOne.3dm, it also started showing the white view ports again.
Here’s my machine info, copied from the OpenGL preferences window:
Software information
Software versions
Rhinoceros version: 5.0 Wenatchee 2014-02-11 (502)
OS X version: Version 10.9.1 (Build 13B42)
Plug-ins
None
Hardware information
Computer hardware
Hardware model: iMac11,3
Processor: Intel Core i3 CPU 550 @ 3.20GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: ATI Radeon HD 5670 512 MB
Memory: 512 MB
Screen size: 2560 x 1440, 1360 x 768
Displays: iMac, hp PL5060N
USB devices
Generic: USB2.0-CRW
Apple Inc.: Bluetooth USB Host Controller
Apple: Internal Memory Card Reader
Logitech: USB Receiver
Apple Computer, Inc.: IR Receiver
Apple Inc.: Built-in iSight
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.14.21
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
hmm… yeah, that file works fine for me and i’ve never had a viewport whiteout like you’re showing while in the middle of a drawing session… (there’s a difference in the two screenshots above- mine doesn’t have viewport labels in there… it’s maybe more of an incompatible(?) .3dm whereas yours appears to be a gpu related glitch.
regardless, this is beyond me… @marlin will have to look into it as he will have an actual clue as to what the problem may be.
There are two different issues here. Jeff found a malformed Untitled.3dm lurking inside the Rhinoceros application. This file is no longer used, and also has some bad viewport positioning information in it. The new UI pays attention to the viewport positions stored in the 3DM file, while the previous UI versions did not. That’s why three of the viewports have no label - there is no viewport at all in that quadrant. Pay no attention to that file. It will be gone in a future WIP release.
Paige’s problem is different and likely the GPU is running out of graphics memory. To get speed, Rhino uses a lot of memory and resources on the graphics chip. Blank viewports with labels looks like there is not enough graphics memory to keep copies of the viewport on the GPU chip.
The GPU needs to share its memory with all the Rhino windows and with all the other applications running at the same time. Plus, I see that you have two displays. Everything displayed on the second display also needs graphics memory.
So, things to try:
Close other Rhino modeling windows except the one you are working on.
Close other applications.
Unplug the second monitor.
In Rhinoceros > Preferences > OpenGL, set Anti-aliasing to none.
Try these things, perhaps one or more at a time, to see what makes a difference. Restart Rhino each time when testing. These are not meant to be final solutions, but to help test the graphics memory hypothesis, to see if that really is the problem.
I was able to recreate the issue by copying the objects in the file I attached above, and pasting them into a new file.
It seems to be fixed now however, after I closed all of my extra desktops!
But before I did that, I had tried unplugging the extra monitor and restarting
but it didn’t seem to be enough.
I also added a few desktops back and it continues to draw correctly now.
Resolved for now, and one more reason I might need to upgrade soon…
Thanks!
~paige
Ahh, yes, extra desktops would also strain the graphics memory usage. Rhino for Mac could have, but does not yet have, a fallback scheme when the computer runs out of graphics memory. This fallback would slow down drawing in Rhino, but at least the program would be usable.
I just looked, and, these days you can get iMacs with 2GB or 4GB of graphics memory. That’s pretty amazing, and is plenty of graphics memory to have multiple displays and multiple desktops, and whatever else you want to load into the computer.
Computer hardware
Hardware model: iMac13,2
Processor: Intel Core i5-3470 CPU @ 3.20GHz
Memory: 16 GB
Video hardware
Graphics: NVIDIA GeForce GTX 680MX 2048 MB
Memory: 2048 MB
Displays: iMac
USB devices
Western Digital: My Passport 0748
Wacom Co.,Ltd.: CTH-460
HP: Photosmart C4700 series
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
Apple: Apple Wireless Trackpad
Apple: Apple Wireless Keyboard
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-8.18.22 310.40.05f01
Render version: 2.1
Appearance settings
Antialiasing: Nessuno
Mip map filtering: Nessuno
Anisotropic filtering: Nessuno
To solve the problem temporarily, before the gate menu “recent files”, then save your work, then close the file and reopen it.
@Zsimon, please try the different things I mentioned in an earlier post in this thread and see if any of them make a difference in the viewport flashing.
@marlin Any idea how to fix the “bad viewport positioning” you mention? A file of mine has this problem - with two viewports unusable. Screencap attached.
