Rhino textures render in an inconsistent manner. I used Rhino’s grid texture just to map my geometries.
Buildings in the top left corner are meshes made and mapped in Grasshopper (thanks to Human plugin) and act fine in external program (UE4). Big buildings are normal breps. Every roof in the scene is using the same material.
I exported those buildings but the most important thing for me is to know why it happened? I have some experience in texturing in Rhino (which is not a very pleasant thing to do). But differences between engines like this are ruining my confidence about my skills in texturing.
I know that I used different methods because I stopped texturing when I saw that Rhino Render is showing something else than Viewport and the same goes for V-Ray. Why it is different in viewport than in render is my concern.
EDIT:
Also the difference in resolution of the texture of the same material and mapped identically (cube matched mapping from the roof on the right) looks weird. Almost like a lens blure from that angle ;).
I don’t see with the red buildings as what you post, the UVs are a bit of a mess there, the surface mapping doesn’t really work for those. I see the same across all display modes and Rhino Render.
Adding to all a box mapping with a box of 100x100x100 gives nicer results in Rendered, Raytraced and Rhino Render.
I’m guessing that a box mapping of 100x100x100 on all buildings will work pretty well.
UVs of the red buildings may look strange because whole geometry and mapping were made in grasshopper. To map them I used BoxMapping component from Human plugin. Thankfully they behave well in Unreal Engine. You got only a small piece of the scene. I couldn’t afford to map them individually. Many of them are placed on different angles so match mapping technique would not work well. Thanks to the grasshopper hundreds of them are mapped individually. Anyway, it’s extremely simple geometry.
Mapping components from Human plugin are a bit limited (but I’m very happy that there are some tools at all - thanks Andrew!) and we really need better grasshopper tools to deal with texture mapping. I will start a topic about that problem soon.
I don’t have Human, but you should try connecting your final geometry to the Custom Preview component, then switch to Rendered mode. The theory goes that you’ll see whatever the GH custom render mesh is, hopefully including the uvs.
What supposed to be a box mapping is recognized by Rhino as surface mapping and looks almost as box mapping (can be good enough to trick you). After turning on V-ray nothing changes, but after turning on Cycles, created geometry reveals its real nature and UV layout changes.
