Seems to be a bug when switching between named views while in viewport Ray tracing mode. The screen changes to the selected named view for a moment then goes back to the previous view.
Hi Scott,
We’ll try and replicate. Can you type SystemInfo into the command line and provide the results? Thanks.
You bet! Here you go.
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07001, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Commercial, build 2023-01-09
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 96Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA TITAN Xp (NVidia) Memory: 12GB, Driver date: 1-15-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.24
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-15-2023
Driver Version: 31.0.15.2824
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\Scott\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.2\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.2.0
C:\Users\Scott\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.2\Substance.Win.rhp “SubstanceImporter” 2.0.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.23009.7001
C:\Users\Scott\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.12.9.865\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
I wasn’t able to replicate on either platform.
Can you try this on a new file?
Place a box. Save named view, rotate save a new named view. Then put into Raytraced and switch.
Ok Ill try that. I do have some meshes that are blocks . Let me try with those turned off as well.
Ok I tried your test, worked as it should.
I tried copying and pasting specific geo from my original file to the test file and tried it. Worked as it should.
I went back to my original file and deleted all layers except the ones with my model. Now it works as expected. So something in the file was causing it to always snap back to the first view . As to what , Im not sure.
Ill keep playing with it. It must be some element from another file from another designer thats causing the glitch.
Thanks for your help
